If I drain fluid from the pan only and NOT the converter, how much fluid will I need to add?
I couldn't find refill amounts in the book or net and I don't want to drain the converter also if I don't have to. I believe it took either 13 or 15 quarts total when it was dry. I did the recomended method of so many quarts, then start, then add, then shift through the gears, then add again. Just wanted to know how much to compensate for how much might still be in the converter, lines, cooler, and tailshaft that may not have drained.
Any ideas so I don't ever/underfill while checking levels?
MoocH
MoocH
