What’s the best to paint my truck frame with? POR 15 or powder coat?
Where they don't get exposed to UV or stones, or other road debris kicked up.Not to be contrary but I have powder coated parts in an engine bay
i used por15 and kbs on my 58 truk frame and underbody. as joe mentions "You can touch them up." which is a big plus when you forgot to weld on a brake line bracket. i also did my frame in sections as i installed the mustII ifs and motor before removing the cab. i did not top coat most of the por15 as it is under the truk out of the sunlight and truk is garage kept. 12 years and 36k miles later i see no chalking or peeling. i sanded most of the frame with a right angle die grinder and then blasted brackets, nooks and crannies.POR and the like are better than nothing and don't require total media blasting. You can touch them up. They are not UV-stable and will turn chalky unless you topcoat.
KBS makes an improved version that doesn't require topcoat.
