any guys with t bucket roadsters with spoke wheels up front what is the tilt back angle you have your axle set at..someone told me 7% cant be right my car steers like crap
Boy, can I relate to that. Back in the sixties with a no budget 47 Ford. Hang on,, she's gunna swap lanes again!!In the 50's My brother had long shackles on his 40 Ford coupe, the cheap way to lower it, He had to add a panhard bar to get the front end sway to stop . As Rwenuts noted, The shakles should be about a 45* angle in the completed car. engine installed, radiator installed etc.
VERY interesting point and well explained.Castor angle and king pin inclination have to work together. bend a paper clip into a T shape, to simulate kingpin and spindle at 0 castor . rotate the spindle end, it stays the same height as the wheel turns. (Some heavy equipment geometry) Now tilt it back to simulate castor with a 90 * kinpin inclination. as you turn the spindle end moves closer to the ground in one direction and farther away the other direction, as the spindle tries to move closer to the ground it raises the vehicle, the weight tries to move the wheel back straight ahead and the inertia can move the wheel past straight and it will lower that side, The Front end can start to "dance". now bend the paper clip to simulate king pin inclination, at 0* castor. as you turn either direction the end of the spindle tries to move closer to the ground, raising the vehicle, vehicle weight tries to return the wheels to straight ahead whether you turn left or right. Now with your king pin inclination add in some castor, as you turn you will get differents amounts of lift depending which way you turn , with a rigid chassis the weight on that side will help point the wheels back straight. as you add more castor you can reach a point where you will get a lot of lift in one direction and Drop in the other direction. that tire will try to "float" no directional stability when turned one direction for that wheel.. Some of the 70's drag cars had new spindles made with around 15 degrees king pin inclination so they could run a lot more castor before reaching the "float point". I the early 60's I tried to explain what was wrong with the local engine builder's Studebaker Bonneville racer front end geometry. as I left I said you will get that thing upside down !!. Two weeks later He ran 5 MPH over the record , then on his back up run it started to "dance" rolled several times, The hemi stayed under the hood but the bellhousing broke apart and the 4 speed went out the backwindow breaking his arm on it's way thru.
