I dropped the tank and ran a grnd wire from a center brass term in the middle of the sender ( I figured that was the grnd term) to the body. The connection at the body was bare metal. Put the tank back up with no gas in it turned on the key and pegged the gauge. Maybe that center terminal is not a grnd terminal? Should I have connected the wire to a sender mounting screw? Thanks Joe
Yes, what boatbob said about the center terminal is for the sender connection on the gauge.
I would suggest running a ground wire all the way from a sender mounting screw to a ground connection on the gauge.
