I like the LT1, but its not for everyone. They are basically a traditional 1-piece SBC with a few key differences, but try buying one that doesn't cost 3 times what it should.
A Vortec engine out of a truck would be a great choice. They're plentiful, cheap, have great heads, and they aren't very complicated. They do have limitations on how far you can go with power since the stock intake has oddball injectors that can't be upgraded, but if you want to up the power, get a marine vortec intake. It uses traditional injectors that can be upgraded. Normally I wouldn't suggest an OBD2 engine like this, but since you are smog exempt the OBD2 can actually be nice since it will have advanced diagnostics that really help figure out problems.
TPI engines are very simple, but a bit limited on RPM potential without expensive intake upgrades.
Most of GM's stuff was PROM calibration up through 93, and Flash calibration 94 and later. What that means is you can use a computer or programmer to fine-tune the later engines, but you have to burn a chip for an older engine. Might make it easier to fine tune things down the line if you get a Flash-managed engine. Its like the difference between a CD-ROM and a compact flash card for your computer. Once you burn a CD, its done. If you don't get it right, you have to throw away the CD and try a new one. A flash card is rewritable, so if you don't get it right you just try again and overwrite the flash memory. This allows tuning on the fly and avoids the time-consuming step of having a chip burned for an outdated system.
