Post the website for the vems system, I've never seen it. You will also want to check out www.sdsefi.com and www.megasquirt.com. MegaSquirt is a DIY EFI controller, or you can buy it fully assembled. It can be done on a budget.
You can use computer controlled ignition. Those two sites should give an idea as to how. The crank trigger is usually a wheel that bolts to the balancer and has an optic sensor mounted on the timing cover. You can also keep your standard ignition system and just have the computer control fuel delivery.
When you use a multi coil system you only have half as many coils as cylinders. Two pistons are always near the top at the same time no matter what engine configuration (four or more cylinders). The coil fires both cylinders at the same time. The one that fires in the exhaust fires weak because a spark jumps best through "clean" air. It's called a "lost spark" system. All the OEMs use this method.
