This is my first post: I have read through some post on J-B weld and I have a question. I am a novice not a hot-rodder but I needed help:
I have a 1996 Chrysler Town and Country van: Wife drives it mostly but today I drove and and smelled gas. Tracked down the smell and it is leaking at the fuel rail where their is a fitting to a u-turn in pipe to back injectors. Manual says the fuel rail in all one piece and so does dealer. Part only availible at dealer $180 yikes !!!
Could i put some J-B WELD putty on there and take care of this. If so do I need to make sure it is clean of all fuel before applying? Because it is still leaking fuel because of the pressure.
Thanks for any advice.
Anthony
Too many hobbies!
For a temporary fix, until you scrape up the bux for the new parts.
You really want to trust your wife's life to $2.00 worth of maybe-fix-it?
Leaking fuel is a big deal, especially on the engine, where it could ignite.
I am the world's biggest rigger. I will jerry-rig almost anything. BUT There are certain things I won't. Brakes are one, and fuel is another.
J-B makes great prducts, but it wouldn't be worth the risk, if it was my family's safety.
You might check out a few salvage yards. Recycled parts are a great asset, and will save you some bux, too.
Come Home Safe Soldier
That is a large chunk of change at Christmas time.But a fuel leak deserves to be fixed correctley.You might be able to J-B weld it,but that is not the wisest path.That needs to be replaced.You may get lucky and find that rail at a boneyard for quite a bit less.Check your local Trader and see if anyone is parting one out.Those vans are in ours all over the place.Good Luck,-Rcastle-
