1 - 6 of 6 Posts
got the stainless fuel lines installed over the weekend,, I picked up a Rigid 377 flaring tool for the 37 degree flairs as I saw that recommended on this forum when I did a couple of searches,,, that is one great tool, flared 3/8 and 5/16 stainless like moving butter..and great looking flairs to!
but my question is,, other than looks, is a compression style fitting just as reliable as a AN flair?
for the steel to nylon adapters I used the Dorman 800-035, that have a compression end to connect to the stainless line, a barbed end for the nylon side.
http://www.dormanproducts.com/p-30430-800-035.aspx
the compression side tightened down nice,, asking,, as easy as the Rigid 377 made a flair,, the compression fittings took the making of the flair completely out of the picture,, so are they just as good?
thanks
WFO
thanks
A compression fitting doesn't have the mechanical strength of a flared joint, IMO. The best reason for using a 37 is it only takes one flare, no need for a double flare so they can be made faster, and possibly on thicker and/or harder hard lines.
It's MY opinion that a double 45 is just as good, if made correctly.
Colbalt327,, what you said,,the point on the mechanical strength,, makes sense to me,,thanks
oh,, and another thing,, installing the barbed fittings on the nylon hose,,
I heated the nylon in boiling water for about 10 minutes and heated the fitting in an oven set at 325...
I had the fitting clamped in a vise grip standing up and setting on a pizza tin,,
they went on fine,,
as an experiment I tried one with just boiling the nylon, it went about half on then froze,, I think the key is also having the fitting hot..just be sure the install push is all one movement, if you stop, you are done.
While not a 'lover' of compression fittings, they will probably work fine under the 8-10 psig that a fuel line will see (I assume that you are talking mech. fuel pump/carb). My question is - why use nylon fuel line and not -AN and 37* the full length?
Oh and that Rigid flare tool - I'm guessing you might have seen one of my posts about how I like it. Several years later after doing mine, not a sign of a leak, brakes or fuel.
Dave W
Irelands Child
I don't post here to often,,but I check this forum frequently and have always got great tips and ideas,,,
on the fuel line what I am doing is installing a 28 gal fuel tank and pump module from a 92 D-150 into my 83 D-150
the 92 fuel pump module accepts a fuel line connector like the Dorman 800-082
http://www.dormanproducts.com/p-9569-800-082.aspx
hence the nylon line..
I am keeping the carb motor from the 83 so I am using a Areomotive 13204 to control the pressure,,
here is a photo
http://www.flickr.com/photos/[email protected]/sets/72157630037480330/
1 - 6 of 6 Posts
