1 - 6 of 6 Posts
Hey all. I realize a leaking diaphram in the fuel pump can allow "fuel" to get into the oil, could it also allow "oil" to get into the fuel? I'm thinking not, but i'm not sure. Thanks for reading my post!.
Keith
I don`t believe so, since oil in the fuel pump area isn`t pressurized like the fuel is. When you change pumps, pack the new pump with lube in the spring area, since this area doesn`t have a direct oiling, without lube heat build up will ruin the pump in short order. I usually use moly or white lube.
every time i use a mechanical pump when they break i end up with feul in the oil never again will i use a mechanical pump electrics are just as reliable now if not better
Technical Support Barry Grant
When ever you're using a mechanical pump in a performance application it's a good idea to use a seal behind it. Seals-it makes these: http://www.sealsit.com/fuel.asp
1 - 6 of 6 Posts
