Hey Guys,
I have been having a problem with my 327 running overly rich for quite sometime. I have been thru 3 different carbs, adjustments and various tuning tricks all to no avail. I have even gone as far as changing to a milder cam and adding a CDI box to my ignition setup.
Today, just for laughs, I installed a fuel pressure gauge. I was watching the gauge while the engine was running at idle and the needle on the gauge jumped back and forth rapidly, then settled back down to about 7 psi, waited about a second and jumped back and forth again. This was accompanied by a slight shudder in the engine and kept happening over and over again. This engine has always run rough and pig rich for no good reason.
I have a Carter Street and Strip electric fuel pump with an internal regulator and no return line. I was told at the time of purchase of the pump that it did not need a return line or an external fuel pressure regulator due to it's having internal pressure regulation.
I guess my questions are:
1. Is the needle jumping around normal when the regulator 'pops' and releases pressure?
2. Is it possible the gauge needle jumping is just caused by fuel inlet needle valve in the float bowl?
3. Could this be the cause of the pig rich condition?
I have had this pig rich problem with this engine for since I installed it 6 years ago and the only thing left to suspect is the fuel pump.
The engine details:
327 SBC, .030 over
10:1 Pistons
.202 Chevy Heads
Comp Cams "RV" flat tappet camshaft w/ hydraulic lifters
Mallory 6A Ignition box w/ Unilite distributor
Weiand Action Plus dual plane intake
Summit 600 CFM Carb
Thanks for your help,
TR
The engine details:
327 SBC, .030 over
10:1 Pistons
.202 Chevy Heads
Summit 600 CFM Carb
TR
