Ok, I just got back from my local supplier. He's a restorer/builder as well. Been doing this stuff 40+ years.
I was asking him about how to put a return line in my system as it only had a single 5/16 supply line and vented cap on the tank. I changed to a 3/8" pick up and line but was thinking of changing the pick up to one that has a 1/4" vent line and using it as the return.
I'm running an electric pusher pump feeding a mechanical on the engine with two 650 cfm Carter's but I was going to put a bypass regualtor in the system. between the pumps.
Since I'm running an electric pusher pump I was worried about over pressure, deadheading and overheating the pump, hence the bypass regulator and return line. He's seen the 1/4" vent line used as the return since mine has a vented cap but since it dumps right over top of the pick up he's seen it aggitate the fuel causing air in the fuel pick up system.
Solution is to weld a bushing in the tank away from the pick up. Not what I wanted to hear. Other options are an on demand fuel pump but I already have the pumps, or just let it run and take my chances. He doesn't think it will burn out and I do run a mechanical pump on the engine as well.
I do need a regulator somewhere in the system but it does it need to be a bypass type?
Opinions?
Opinions?
