1 - 6 of 6 Posts
i put a 600 cfm holley on my 403 olds and i have a push style electric fuel pump 4-9 psi with a holley 3way fuel regulator 4.5-9 psi. The fuel regulator has a input on the bottom and a output on each side.
I want to know what psi should i run.
Do i run 1 output to the carb and the other output as a return.
You need to keep the fuel pressure constant through the one outlet to feed the carb. Using the other outlet for a fuel return line would just bleed 4-5 lbs of pressure back into the tank. Fuel return lines are really only needed for fuel injection. At least that what I use them for.
1 - 6 of 6 Posts
