I have a 2000 blazer tank for my truck, but I need to modify it by welding up the old sending unit hole to make way for the 5 hole unit I got. I was going to use a stock sender, but the new tanks are integral sender pump units, and the pumps put out 60 psi! so I was thinking of welding the sending unit hole closed and then adding a new seperate pickup, sender, and vent elsewhere on the tank. The welding shop says this will be quite an undertaking cause they will have to purge the tank. So now I'm thinking maybe I should just give up the idea to do this junkyard tank and get on of those generic pickup tanks. For a little over $200 I can have a tank that will accept all my fittings, already have baffles (the blazer tank does not), and be reasonably easy to fit in. I don't know the welding cost, but its probably gonna be over a $100.
The only reason to do this with the blazer tank was to say that I adapted something from a late model vehicle to work on an old truck, but I don't have the time/knowledge to chase down the parts and get the modifications made. I never thought this was gonna be such a hassle when I got into it.
I just want to hear some other peoples advice on this. Thanks in advance.
