Banned
I would like to put the filler neck and cap in my trunk. I know what your thinking, is this guy nuts. I'v seen it in a lot of car books but thay never get into details. I know you need a sealed cap of some kind, but what do I do with the vent. Any one who has done this please let me know. Thank you.
boatbob2
fuel filler cap
Hi,after you remove the fill tube from the gas tank,i would braze a piece of copper tubing (small tubing 1/8?) to the fill tube,close to the trunk floor,and either run the tube thru a small hole leaving it down 6 to 8 inches, and aim the tube toward the rear of the car. or add a piece of gas hose and run it thru a hole in the trunk floor. im boatbob2
Use a sealed cap w/ no pressure relief valve built in & splice in a small line of tubing from the main hose that runs outside of the vehicle. In the racing industry we use a $16 1 way check valve found at Summit or a similar company that you install within the hose.
