I don't know if any of you have seen this before but after letting my 69 Camaro drag car sit a while, when I went to turn it over, the engine would not crank. Plugs were removed and when the engine was cranked, gas came out of the plug holes in #7 and #8 cylinder. I sure it was gas and not water because it was colored blue like the fuel (VP C12) and it evaporated right away. After rotating the engine and clearing the cylinders, the engine would crank ok with the plugs in. I have not fired it up yet. Often I would activate the fuel pump when it sits for a while to avoid having the gas evaporate out of the carb (Holley 4150). The car is usually kept in a hot garage (85 degrees). Could it be that when the engine was turned off last that the #7 and #8 intakes were in the open position? Maybe the gas did evaporate out of the carb and when I turned on the electric fuel pump initially the floats were stuck and a lot of gas could have poured into #7 and #8?
Any comments? Do you see any issues with firing up the engine? Should I throw some oil in the cylinders first in case the gas "washed" down the cylinders?
Any help would be welcome.
