Greetings. I have an engine I put together, my first and only, about 10 years ago. Car's been a slow project.
It's a '77 first gen 350, bored .060 over, Scat 383 rotating assembly with KB dimpled alum. pistons - 9.5/1. Heads are GM performance ("fast burn") mild port and polish, MSD 6-A through an HEI cap. Wolverine "Blue Racer" wet cam, intake is ~ '63? ~ Hilborn re-ported for MegaSquirt 2 EFI.
After a bit down the line (wiring disconnect through firewall issue), it fired right up!. But idled fast ~ 2200-2800+ ~ fiddled with TunerStudio and got it to stay about 2200 for break-in. A few years later ... that's another story ... fired right up and idled nice - 800-900. Ran rough and stinky, but ran a few 2 mile turnarounds, up to 3200. But the last little trip to test stiffer rear coils, it seemed extra noisy, I thought I may have heard a faint little snap ~ and it seemed to run a bit rougher that last 1/4 mile home. I shut it off, but restarted to pull it in garage and noticed a lot of "smoke" out the pass. side exhaust (separate exhausts). I'd seen some smoke before, part of the over-rich-ness. Pulled rocker covers ~ nothing broken. Pulled pan and ~ dirty grey soup ~ water in the oil. Pulled plugs and #8 leaked clear water out - for about a 2 hour drip.
My novice head says, head gasket, or cracked cylinder. Compression check this morning - all 153#+/- but #8 is consistent 149# over several rounds of checks.
Is that enough of a difference to indicate gasket?
