1 - 6 of 6 Posts
Premium Member
What I did was found some of those rubber gaskets with a metal insert, and then basically glued them to my valve covers using weatherstripping adhesive, let it dry totaly, and then slapped them on without anything on the bottom. They dont leak a drop and are totally reuseable.
Don't know how often these gaskets need to be removed on these engines, but if you take it off occasionally, put some wheel bearing grease on the gaskets. This stops them from sticking to the block and wrecking them.
1 - 6 of 6 Posts
