Okay, I pulled the cluster out today, and There are two connectors, one is gray and the other black. There are 10 terminals in each. Only two, out of the twenty are hot though. One on the gray and one on the black. And one of them(not one of the hot ones) when I stick the tester in it the door buzzer comes on. I don't know if thats important or not, I'm not sure why the buzzer would be running through the gauges. But anyways, when I put it back in, some of the gauges moved aroun a bit, nothing to indicate that they were working though. The voltmeter moved a bit, as did the oil pressure and fuel gauge. The water temperature, tachometer and speedometer didn't move at all though. Where do I go from here, do the wires go straight to the body control module? Where is it located at? I appreciate everyones help very much.
