1 - 2 of 2 Posts
I built a racecar that has to run a 7.5", 10 bolt GM rearend. The frame of these cars are 1978-1987 GM midsize cars(Regals,GrandPrix, Monte Carlo,etc.) I have gear sets of 2.28, 2.41, 2.56, 3.08, and 3.23. The 3.08, and the 3.23 bearings are in bad shape. Will the bearings off of the other gears work. Also how hard is it to change these gears.
Chopper Builder o<>\o
changing the gears is best left to the professionals. It doesn't cost much (mine cost $135). If you do it yourself, it will be a hit or miss. Gotta shim it properly.
1 - 2 of 2 Posts
