Alright, three questions guys concerning the Gen VI 454 BBC.
First, in order to mount the oil filter, all I need is the threaded insert for the oil filter right? This little guy http://www.summitracing.com/parts/NAL-3853870/Application/?prefilter=1. Is GM the only ones that offer it, or would a local hardware store have it you think? I wonder what thread size it is.
The second is, does it need the crank reluctor ring? As in, will the dampener go too far in if I don't use one or for some reason not seal right? I'm not running EFI, or any other sensors, I'm just concerned that the dampener will go too far in if I don't use one.
The third question is about the oil pan and the oil pickup tube clearance. I know the rule of thumb is that the oil pickup tube screen should be 1//4 to 3/8" from the bottom of the oil pan. My OEM GM 6 quart oil pan came with a pickup tube and melling M77G oil pump (same thing as a M77). The problem is that, the pickup sits a full inch (1.10" without gasket to be exact) above the pan, ***! The pan is 9" deep. The pickup tube is 6.05" long. I tried a Melling 241S pickup tube that is used with 8 quart pans on Mercruisers. That tube puts the pan 0.90" from the tube. I am so frustrated, that I am about to cut the collection of pickup tubes I have, splice a section in, TIG it, and be done with it.
