hopefully you guys can help me
i just finally got my car back together and running my problem is that my header glow when i hold the engine at a certain rpm above idle i held it at about 3000 and they started to glow also i get a backfire if i hit the throttle to fast when i open up the butterflies fast form idle it backfires
here are some specs maybe they will help
sbc 350
weiand 177 blower
msd
holley 750 double pumper
488 cam
edelbrock rpm heads
fuel pressure is at 6 psi
cam is installed straight up
timing is at 10 deg btdc
it seems to run way better when i put more timing in it but weiand recommends not putting any more that 6-10 deg of intially timing. Does that change is i have a strictly mechanical advance distributor as opposed to mechanical and vacuum advance?
the engine holds 15 hg/mg at idle just fine
thanks in advance for your help
sbc 350
weiand 177 blower
msd
488 cam
edelbrock rpm heads
