1 - 11 of 11 Posts
Banned
any ideas wat causes the upper intake to explode on the gm series II 3800 engines?
we looked at a 2000 something bonneville a bit ago to maybe pick up as a repair job
and wow the entire upper intake is busted apart
too much fuel ?
bad MAF sensor?
pressure regulator?
wow..
I've never heard of one blowing up but i know the Series II 3800 had issues with the intake manifolds. Leaking gaskets and cracks/breaks. The intakes are plastic, as they are on many engines nowadays. And yes, they were recalled. I dont know if they fixed the issue so it doesnt happen again or if they just fix replace the intake with a new part and call it good.
Banned
Discussion Starter · #4 · (Edited)
well it wasnt using water or burning it or anything like they usually do
it literally exploded apart
whats the cause?
does anyone know?
is the engine toast?
or is it something that is fixable with a sensr and new intake
or what ?
i need to find out ASAP quick like yesterday
leakign water due to a crack was dirt common yes we have replaced many
but thats not whats going on with this one
at all
dealer service counter guy said he has never seen or heard of one do this
http://www.automotivehelper.com/topic501452.htm
bad fuel regulator
ruptured
fuel sucking in throguh the vac hose to it
mis time spark and cranking
kaboom
found the answer!
thanks!!
WFO
About all I can think of is a hung intake along w/intermittent spark/no spark that would allow a lot of fuel to collect before igniting explosively. If it did it once, there's no guarantee it won't happen again unless you for sure find and fix the cause. Could've done a lot more damage when it went boom, too. Sensors, injectors, who knows. I'd pass on it.
Banned
buying the car today for dirt cheap 400 bucks its a spotless car blueleather interior silver gray color only one minor ding in the entire car body no rust
we will fix this real quick and sell it for around 3k or something
we have lots of 3800 intakes and rails with regulators and MAF snesors from so many 3800 engine swaps weve done
so it will be free repair
time to hook up to the car trailer
thanks
Saitek5678
saitek5678
Now I remember, yes, all it takes is a backfire through the intake and you can call it a day for for plastic.....Thoughs engineers at GM....my god! I guess they will get paid regardless thanks to Obama.
01 Bonneville
I have an 01 bonneville that did the same thing, I just bought it for 500.00 bucks can you tell me did the fuel regulator fix yours? I was thinking it was the regulator or maybe a bad injector but wasnt sure. please let me know
Thanks
1 - 11 of 11 Posts
