ok i need to find out some info on the late 80s mid 90s little 60 degree gm v-6 engines
theres the 3.0L in the late 80s
theres the 3.1
the 3.3
the 3.4
and the 3.8
now, we are removing the cylinder heads on a 97 3.1 currently to replace a leaking head gasket and i was always under the impression that the 2.8 and 3.1 were identical engines and had conventional heads that did not split at the pushrods like the 3.4 heads do
well i was wrong
these 3.1 heads are split design
recently i was working on a 3.4 engine for the first time ever, in a 93 bird, and well i found out about this split head design the fun way.
we used to have an 88 or so grand am with a v-6 engine we had to remove and install the heads on it twice due to bent valve issues
i could not remember what v-6 was in it
but i looked it up online and found that it would have been a 3.0 engine for a couple years i didnt even remember about and from what pics i could find of 3.0 heads they are old conventional non-split style
now, when i look up cylinde rheads for a 3.0 it comes back with 3.8 heads also
and when i look up 3.3 heads it also comes back with 3.8 heads
so apparently these three engines all use conventional non split style heads ?
and the 3.1 3.3 and 3.4 all use split style heads ?
right?
i cant believe i ahve bene wrong and been confused this long
i thought only the 3.4 was the oddball with split heads
wow.
hmm
thanks for anything
theres the 3.1
the 3.3
the 3.4
and the 3.8
well i was wrong
right?
wow.
hmm
thanks for anything
