Why do you want to put a '70s GM alternator into a '90s Ford ? A better bet would be the stock alternator or upgrade to a Ford 3G.
Large wire is obvious.DoubleVision said:Anyone have any tips on wiring a GM 10si Alternator to a
'94 Ford harness? Any helps appreciated.
Just to clarify slightly, if you are not using an alternator idiot light, the #1 terminal needs about a 35 ohm resistor between the alternator and the switched +12v source. That's about the resistance provided by the GEN bulb on GM cars. NAPA actually sells a short jumper harness with the resistor built in.T-bucket23 said:Large wire is obvious.
#1 terminal, find the wire that is hot when the key is turned on
#2 terminal should go to the wire that is hot all the time as this is the voltage sense wire.
If you tell me what vehicle I can probably get you wire colors
OK, for the electrically challenged among us, a bulb IS a resistor. That's why the filament heats up and glows when you flow current through it. That's also why when you wire bulbs in series, they get progressively dimmer as you add more.EOD Guy said:The exiter wire #1 terminal doen't need any resistor to compensate for the light bulb......
The bulb is just an idiot light....
joe_padavano said:Just to clarify slightly, if you are not using an alternator idiot light, the #1 terminal needs about a 35 ohm resistor between the alternator and the switched +12v source. That's about the resistance provided by the GEN bulb on GM cars. NAPA actually sells a short jumper harness with the resistor built in.
