Now You Got Me Thinking!
Alright, this may be a little dangerous, but you've got me thinking about this more than I probably should (lol).
I found two articles from Chevy Hi Performance regarding roller cams and the different designs and accessory requirements. Both have good pictures depicting what has already been said:
1.
Roll it Over
2.
Don't Walk!
The first article talks about putting a factory roller cam in a pre-87' block and that it can be done, but you have to cut off the tangs on the original retainer plate. Other than that, there is no detail. The second article has some good pictures of the thrust buttons I was talking about.
I talked to my engine builder about this and he thinks it can be done, but the hardest part will be getting a thrust button to work with the upper sprocket of the factory roller timing chain. The reason you cut off the tangs and keep the original retainer plate is to maintain the proper alignment of the two timing chain sprockets. It will be nothing more than a spacer plate between the cam and upper sprocket. You may even be able to get a torrington bearing to install in lieu of the old retainer plate.
As far as the thrust button goes, if the hole in the upper sprocket is the same diameter as an early style sprocket, you are good to go. If not, you will need have one machined to fit, probably out of brass. It does not have to be a roller button. I prefer the
nylon buttons from Comp Cams. You may even be able to use the nylon button and carefully sand down the diameter if the hole is too small in the late model sprocket. Either way, to adjust the end play with a nylon button, you sand the engine side (bigger end) ever so slightly until the proper end play is achieved (like .005"). You may even be able to use the
Cloyes two-piece cover with built in thrust button.
Without actually having the two different upper sprockets to compare, I am unable to verify if the thrust button will work without issue. Maybe someone else can answer that for you. Either way, I am now sure that you can use that free cam in the non-roller block. Be sure to let us know how it works out.
Good luck, Ed
