RodFather said:
most gm's are the same....
orange- dimmer (if applicable)
yellow- constant power
red- ignition
black- ground
blue power antenna (if applicable)
speaker wires (can't remember if front and rear are correct..you'll when know when you fade)
front right
gray- speaker positive
gray w/blk stripe- speaker negative
front left
white- positive
white w/ blk stripe- negative
rear left
purple- positive
purple w/blk stripe - negative
rear right
green- positive
green w/ blk stripe- negative
Woaaa, that is not GM Factory wiring! That is the standard wiring colours for the aftermarket stuff. Gm radio harnesses don't even have a red coloured wire in the harness.
After about 1980 and probably earlier, this is GM standard:
yellow=12v acc.
orange=12v constant
lt blue=rr spkr -
dk blue=rr spkr +
yellow=lr spkr - (not to be confused with yel 12v acc)
brown=lr spkr + (not to be confused with brown park light wire)
dk green=rf spkr -
lt green=rf spkr +
gray=lf spkr - (not to be confused with with gray dimmer wire)
tan=lf spkr +
gray=dimmer switch
brown=park lights
black/white stripe=ground
Marc
