G'day everyone.
I've just replaced a few fairly rusty sections of my '74 Holden ute (that's australia's chev el camino, if you've never seen one...), along the rockers and in the wheel arches. I welded in new steel with a MIG, it's not a perfect job but a little bit of filler and no-one will be the wiser.
The car was painted by someone about 5 years ago and the rust was not repaired then, so I'm guessing a lot of the prep work left a bit to be desired, so I'm going back to bare metal for the whole thing.
The problem is that I can't really set aside enough time to completely bare-metal, then prime, the car. And it's fairly humid air, so I wouldn't want to leave anything exposed for long at all. I'm thinking I could strip an area (say a quarter panel), get rid of any rust with a wire brush on an angle grinder, treat it with one of those phosphoric acid solutions, and then prime immediately. Rinse and repeat for each section of car...
Is there anything there that seems wrong?
Also, the car isn't dead straight and will need some filler to look perfect, so I'm wondering if I can apply filler over the top of primer in extremely thin coats? Or does filler need bare metal to stick well?
I've got a bunch more questions but I will spare you the trouble for now... I'll ask them as the need arises.
Thanks for reading.
Col.
Thanks for reading.
Col.
