On your battery drain test you really need a amp meer between the batter post and batter terminal. If it's above 1/2 amp, begine pulling fuses one at a time till it drops to .5 and you at least know what circuit it is. Likely a stuck door switch or possibly heater relay, possibly a alternator.
If your thinkig ground, Start adding them. You cna replace or just as easily add more using 18g wire and cheap hoops for ends. More is better. Clean off the area, grind or sand it shiny, add your hoops and a dab of dialectric grease run it the nut or screws down.
