Doc here,
imp:
If your sure the fuse link is good (and there are usually more than one..) you must have melted a connection on the SWITCHED Ignition support buss..(the other 10 ga red wire coming off the starter big bolt wire..) Inspect that wire carefully.
Sounds like only the unswitched and ACC support busses are still working, but not the SWITCHED buss. This would have burned out when you shorted the starter. The stereo would work partially because it had memory power but no main power..( the red light, and "Goodbye") in RUN.
You may have suffered a burned out NSS when it all first began, making the starter not work, and exasperated the problem after the short..OR it could be the Ignition switch is failing..(dirty or pitted contacts)
Did you say you tried to jump the "S" and big bolt wire and it had no effect? If so, and you got the right two wires, (not the "I" terminal) then it may be the cables are shot, or the ground is missing from the battery to the block to the frame.
Check your battery cables first, then the support buss wire, from the starter to the Fuse buss, Be sure your block, Frame and firewall has a good ground, Then, get a DVOM and take measurements on the "S" wire in start for 12 volts, and the "Batt " Wire on the HEI for 12 volts in the "run" position.
IF you have no power, and the wire and links are good, I'd suspect the fuse buss has a wire at the switched buss bar (rear of fuse block) that has cracked or burned off the fuse leg.
IF all is good, and it still won't crank, the solenoid is the only suspect left..
Doc
imp:
Doc
