1 - 8 of 8 Posts
What years and vehicles came with GT40 SBF (5.0) heads and intakes? I would like to look in some salvage yards to find some if i decide to keep my truck. I find plenty of them on eBay and craigslist but it seems they are worth more sold separately than a whole engine is. My truck is an 87 F-150.
I found one pair of the desirable iron GT40P for $50 and still kick my butt for not buying. Most since have been in the $100-300 range/pair. You do need to be careful which GT40 heads you buy as some of the aluminum versions aren't as good as the iron GT40P - which come from the '97-'01 Explorers
The GT40P is a good head for a stocker,the down side is the spark plug location gives people fits with most brands of headers which makes the GT-40 a better choice,this is a good source to track them down: Search Craigslist: Free Craigslist Search Engine to search ALL Craigslist going rate is $200-$350 a pair.This site is a good place to check out classifieds The Corral a lot of guys here are upgrading heads and selling to fund their project also SBFTECH.com Experienced Small Block Ford Tech - Index is another site to watch.
Thanks guys. If the GT40Ps are in the 97-01 explorers, where do i find the GT40's (without the P on the end)? Sounds like i might not want the GT40P's if i am going to have problems with the spark plugs hitting the exhaust manifolds/headers. Currently I have manifolds still and since i am working on a budget i might have to run manifolds for a while. It sounds like the plugs on the GT40P might be in the way of the manifolds.
These are the GT40P iron heads. You can see that plug placement can be a problem even with the Sanderson Headers, though only one gives me a fit. This is NOT anywhere close to a stock engine but not an all out HIPO and they are well suited for my use.
Do your homework and be aware that some versions of TFS heads are a poor choice for a stock engine or those without correct pistons for those heads. Also, some versions of Ford GT40 aluminum heads were used in some early '90's high performance Mustangs - and are not really a very good head when compared to most of the name brand after market independent offerings or even the iron GT40P.
The GT40 head is worthy of a book. Basically it comes in two versions GT40 and GT40P.
The P is a much improved version but because of the spark plug reloacation has serious clearance problems with headers. Still no pain no gain, if you're after serious power the GT40P is the head to get.
The GT40 head can be found on some 5.0 93 through 95 Mustangs and Lightning pickups and later on 96 into 97 Explorer's and Mountaineers. These have a larger 65 cc chamber. On the outside there will (or at least should ) be 3 cast in lines on the end of the head for a first clue as to what you're looking at. GT40P will (should/might) have 4 lines. Regular production 302 heads will not have any of these.
The GT40P should show up starting in 97 through 2001 Explorers and Mountaineers for sure and perhaps some pickups. The GT40P uses a smaller chamber of 60ccs. The GT40P relocates the spark plug and cleans up the exhaust port
The GT40P is a really nice piece and delivers power to the SBF the way the L31 Vortec does to the SBC, but because of the spark plug location the P head can be a real PIA in some installations with the exhaust tubes.
1 - 8 of 8 Posts
