I a looking into the option of buying one and using it behind a SBC just wondering if a stock chevy bellhousing will bolt up and if any Hurst 3 speed manual shifter will work? Is the clutch used a standard GM 10 spline?
The trans to bellhousing bolt pattern is different from the Muncie/Saginaw pattern. The BOP bellhousings in these cars came with both bolt patterns tapped.bighotroddin said:I a looking into the option of buying one and using it behind a SBC just wondering if a stock chevy bellhousing will bolt up and if any Hurst 3 speed manual shifter will work? Is the clutch used a standard GM 10 spline?
bighotroddin said:I am actually building a 27 T roadster with a 283 Chevy. For some reason I have my heart set on a manual 3 speed I guess for nostalgia reasons. From the guys I have taked to said that I would not be happy with a Saginaw as they don't take much abuse. I only want to build this thing once as it is mostly kustom anyway. Thats were some internet reading got me onto the FOMOCO trans that was used in the GTO's beacuse the transmissions that GM had at the time didn't hold up. I know it probley was going to be more money but I was going to buy a scattershield anyway.
x 2. In something that light the Sag will live forever. Good luck trying to find the "special" GTO three speed, it was only used a year or two, and most people bought 4-speeds or automatics. It's pretty rare.junior stocker said:In your case, small CID and lightweight car, a 3-speed Saginaw is just fine. NOT the early Muncie 55-65 3-speed that for some reason gets called a "Saginaw". The full synchro 3-speed Saginaw will be more than adequate. OR, you could get lucky and find a 69-70 full synchro MUNCIE 3-speed; those are stronger. As far as the Ford Dearborn 3-speed goes, if the OP of this thread has it, and the required parts to put it all together, fine, otherwise pass on it.
I don't believe that is correct. The "Dearborn" (don't call it a "Ford"ericnova72 said:The trans to bellhousing bolt pattern is different, the front bearing retainer that pilots into the large bore hole of the bell housing is different size(too big IIRC), the input shaft is too long, and I believe the input shaft is 1/16" smaller but still 10 splines. It isn't an easy adaptation without the Lakewood bellhousing for a ford trans to chevy/BOP engine. The shifter will work with the correct linkage package and the correct trans mount plate.
