I was given a Sanborn 5hp Black Maxx compressor from work. It's a 2 stage and was rated 20 CFM at 100 PSI. We used it as a secondary until the motor quit starting. Bossman wanted a shiny new IR model with an after cooler to match his old one so I got this one.
The compressor head on it works, but it needs rebuilt as it blows oil externally. I have the motor at the electric repair shop getting whatever it needs, probably a capacitor.
BUT, the pump rebuild alone will cost more than a HF twin cylinder single stage that generates 15 CFM, and since this is just for my garage, turned on once in a while, that will be fine. I have a 110v compressor that does 5.3 SCFM @ 90 that I could tag in should I really need the extra 5 CFM.
My question is the speed.. The original pump ran at 1,147 RPM per the tag and the motor is 3,450. The HF pump has a max of 1,050.. 97 RPM going to blow it up?
