1 - 20 of 26 Posts
I have an 84 Z28 with a non computer controlled quadrajet. It starts fine in the morning, tap the key and it fires and there's no smoke at all. If I drive it and let it sit for more than 10 minutes then it will not start unless the pedal is to the floor. A lot of white smoke comes out of the tailpipes when it does fire up. I am not losing any coolant or oil. Any help is appreciated.
The carb is a rebuilt one from an ebay store. I did not see any gas leaking in but I did see some fuel vapor/white puff of smoke coming out by the choke blade
Google "Tunnel Ram 406"
Your Qjet has a spring that pushes the choke closed even if the car is warm as soon you shut the motor.
It sit right in front the choke diaphram. Remove it. It's causing the carb to flood.
Could you explain what the spring's purpose is? Or does it just push the choke closed. What would happen when it sits over night and I try to start it in the morning? Would the choke still be open?
Choke is open in the morning till you step on the gas. Then it closes and sets the choke high idle in to place. When you fire up the motor the choke pull off opens the choke blade about 1/4 inch. As it warms up the choke blade slowly opens and when you tap the gas the choke drops out of place and your motor idles at it's normal setting.
A choke that stays partially closed doesn't make it flood. It makes it run exremely rich.
Something stuck in the needle/seat makes it flood. Or a sunk float makes it flood.
Like cdminter said. Could be rebuild time or take it apart to see what's in the needle/seat.
Here's a link on quads. Explains everything in there.
Quadrajet Info by Lars - Corvette Forum : DigitalCorvettes.com Corvette Forums
I did not mention the spring that control the choke with temperature. There is a tiny coil like spring that the minute you shut the engine it shut the choke closed right away. Even if the motor is very hot.
If the motor is very hot and the choke is set right then the choke won't even move. If the choke is adjusted too rich it will close a bit and might even set up on the high idle.
One note: Not all Qjets use the spring. The one that the choke stays open after you shut a hot engine does not have the spring. That is way it suppose to work. As it cools slowly the choke flap will close slowly.
Please note:
All quadrajets use a spring. Actually a bi-metal coil. Whether in a choke stove attached to the intake or in a housing attached to the carb in a hot-air choke or an electric style that uses 12 volts to heat the coil.
And none will close slowly when it's hot until you step on the gas pedal and release the choke lock out.
Tag!! You're it!!
Sorry for the confusion, It's not the bi-metal I'm writing about. A while back I bought a new Q jet for a 350 69 Caprice. The minute I shut the car off and try to start it later, it would shudder and smoke at tail pipe and smell of gas. It started fine when it was cold. It had that little coil spring . I grab a needle nose and removed it. My old Q jet did not have that spring so the choke would stay open when the motor was hot. It would start up right away. A friend cross the street had the same thing his Chevy 2 barrel dual jet, and could not start it once it was hot. He also removed the spring when I told him. After that it started with no problem.
Thanks!
I don't know why it would do that. I'll ponder it a bit.
Only reason I was in clarify mode was I was concerned we might confuse the OP too much.
My apoligies to the OP for jackin' his thread and apoligies to you lg for the rant.
Discussion Starter · #17 ·
I'm not seeing any spring that could be removed. Here are some pictures of what the carb looks like half an hour after shut off, carb and throttle are untouched. Just to see if anything is not where it should be/I don't see something obvious. Could a hot fuel pump be a problem?
The Qjet in the photo does not have the spring behind choke pull off diaphram housing, Other Q jet does have it.
Like I wrote before not all Qjet use the spring.
A hot fuel pump won't be a problem.
Originally you said you saw a wisp of vapour coming out by the choke plate. That indicates a high float due to something stuck in the needle/seat or possibly too much fuel pressure. After you warm up the motor leave it running and look into the carb below the choke plate. You might see a little raw fuel in there. And you might hear a slight crackle inside too. It doesn't take much flow to cause it to flood.
You might need to pull it apart to check the float and needle/seat.
First try the look see in while running (use a small flashlight to see better). If you see fuel then tap near the inlet with the end of a big screwdriver. Sometimes that will dislodge any junk in the needle/seat.
Or while running pinch off your fuel hose with some pliers, hold it about 10 seconds then let it go. That might flush it out.
Here's a link to a quad rebuild with pics. The carb there is similiar to yours except for the other pull off pot on the front.
Ken's QuadraJet
1 - 20 of 26 Posts
