Here's the skinny, picked up a 350 sbc recently, was told timing is locked in at 34 deg because of a small nitrous shot, I checked the timing to verify the 34 deg advance and the timing marks on the balancer were nowhere in sight. After checking tdc, the ring on the balancer appears to be 180 deg off, (double checked with old non digital, non dial back timing light). The balancer is a mystery, I've searched the internet with the numbers from the balancer and came up with nothing. It looks alot like the Summit series "Bracket" balancers (clear coated, 6 tapered socket head screws around the outer front face and bolt holes for adding weights) so I called Summit with no luck. I know that a balancer ring can slip, but 180 degs exactly? I haven't put a piston stop on it yet to verify that it's exactly 180 off but it appears to be. Which leads me to the main question, are the 6 bolts around the outer front face of the balancer related to the ring? if so, can the ring be rotated 180 and re-installed? If not, I can Always just add some timing tape etc.
Thanks in advance for any replies.
Here's a pic from Summit
