1 - 6 of 6 Posts
Sounds like you will need to lock the crankshaft. If you have a the engine out of the car you put a couple of flywheel bolts in the crankflange & use a prybar to lock the crank against the engine stand.
http://www.warsprints.com
cutthroatkid said:
I'm trying to remove the harmonic balancer off of my 305 I got the gear puller on but it only turns so dar&the the balancer its self starts turning what do I do?
If you have the spark plugs out, put them back in and use a 1/2" drive impact on the puller. Much easier than a ratchet or wrench.
1 - 6 of 6 Posts
