I need some advice on what cam to run. Here is what I have.
I intend to use it for: Street performance with weekend track runs. Want to keep low torque for the size of the car, snappy throttle, but nice high rpm pull
1969 Ford torino formal roof, 3400 + lbs
Ford 302 +.030
5cc stock type notched pistons
AFR 165cc runner, 58cc chamber heads (sweet lil heads)
Alum 1.6 roller rockers, stud 3/8 mount
Compression will be 9.2 - 9.4
Stock converter (as of now)
3:73 gears
long tube headers 2.5in exhaust
600 cfm edelbrock carb
Edelbrock RPM (1500 - 6500+) or Weiand Stealth (idle to 6000rpm) manifold
hydraulic flat tappet lifters / cam
OK...now the cams I have been looking at, they have been all over the board in duration and lift.
Comps 270H (so far my best choice)
Operating Range: 1800-5800 RPM
Duration Advertised: 270° Intake / 270° Exhaust
Duration @ .050'' Lift: 224° Intake / 224° Exhaust
Valve Lift w/1.6 Rockers: .500'' Intake / .500'' Exhaust
Lobe Separation Angle: 110°
Edelbrocks Performer RPM's
Operating Range 1500-6500 RPM
Duration Advertised 290° Intake/300° Exhaust
Duration @ .050'' 224° Intake/234° Exhaust
Lift @ Valve .496'' Intake/.520'' Exhaust
Lift @ Cam .310'' Intake/.325'' Exhaust
Lobe Separation Angle 112°
Intake Centerline 107°
Intake Timing @ .050" Open 5° BTDC
Close 39° ABDC
Exhaust Timing @ .050" Open 54° BBDC
Close 0° ATDC
or
Comps
Xtreme Energy XE262H Hydraulic Flat Tappet Camshaft
Lift: .493''/.500''
Duration: 262°/270°
RPM Range: 1300-5600
I dont run anything that will require vaccume, so lopey idle to me is good.
But I have no idea on how much duration vs lift for the size or car to get good low end torque and hi rpm HP. Any advice would be well advised,
Thanks,
Ford 302 +.030
3:73 gears
Close 39° ABDC
Close 0° ATDC
or
Comps
Lift: .493''/.500''
Duration: 262°/270°
Thanks,
