You should get a diagram for the vehice and check all the wires that were re-connected first.
Check for power at the brake light switch
Check the turn signal switch, the brake lights go through this switch. This is a high failure item on an S10.
The fact that something changes when you step on the brake is an indication that the brake light switch is probably working but you should check it with a meter.
trying to track down an electrical issue without a diagram is very difficult. You should be able to find one on line
