I am researching the build of a 1976 351windsor block, and I am looking for some advice.
The engine is going into a 1970 F100 with 3.03 three speed manual, and an 8.8 inch rear with 3.55:1 gears. The truck is currently running the original 302.
I am looking for really good torque- in the 400lb ft range and somthing like 360 hp. While I am at it I am going for the absolute best mileage on 89 octane fuel possible. I am looking for roughly 9.0 compression to keep away from detonation.
The plan is to punch the block thirty over, and add a stroker kit by Eagle to bump her up to 392 cubic inches. It is getting forged pistions and rods, an Edelbrock preformer RPM air gap intake, and a 625 Road Deamon carb breathing through a K&N
I am having trouble picking a cam and heads.
I have been leaning twards the TFS twisted wedge heads, Aluminum with 170 cc intake runners and a 2.02 inch intake valve.
The other option is the Preformer RPM heads, which I know little about.
The camshaft is a big question mark. As I am running a manual transmission and this truck is my daily driver mileage and low end torque are big concerns. I also have the joy of driving in some pretty ugly winter conditions so a decent idle is a good idea.
I am thinking the Comp Cams Extream Energy XE250H camshaft- 206 212 duration at .50 inch lift is a good choice.
I am going to run roller rockers to help keep the valvetrain in top shape, and lose some friction and wear.
My general theory for this beast has been go for the best flow I can get out of my breathing assembly, and reduce friction as much as possible, and use the camshaft to keep the mileage in check.
I should have also mentiond that I am running a 2 1/4 dual exhaust system with 1 5/8 inch primaries on long tube headers.
Any advice you experianced wrench twisters have would be very much appriciated. If anyone with a desktop dyno program is willing to pull the specs for me that would be really cool!
Thanks.
Scott McGee
Thanks.
Scott McGee
