I recently picked up a 350 Chevy short block that has a 4 bolt main, domed pistons and supposedly a cam with a lift of approx. .525.
I do not want to tear it apart because it's a recent rebuild, but according to good/reputable friend that the engine ran in the 12s with no problems.
I have a Weiand Tunnel Ram with 2 450 Holleys which I plan on using with Steel heads that are 2.02/1.60, with 64 cc heads. They have been slightly ported.
The ignition I am planning to use is a Unilite distributor; haven't decided to going with an "MSD" box or not.
Also, would like to use my Crane Roller Rockers which are 1.6s.
My question is whether or not it is possible to bring the compression down to a usable level to run on pump gas using a thicker but durable head gasket? Or, any other thoughts? The engine will be going into my 69 Chevelle.
Please add anything else that you think I may need to know.
Thank you!
Thank you!
