So I on this 540 after I torqued the heads with felpro 1017 gaskets, I realized I needed the heads loose to thread in the studs that go into the underside of the heads from the lifter valley. Anyways, if your familiar with the underside studs or not, here is the question:
I know these head gaskets are one time use only. But if you only torque the head, and then untorque it, and then reinstall it, do you think leaks will ensue? I know anything is possible, when I removed the head after I torqued it, there was a fair amount of the blue sealant material stuck to the head surface.
Thanks
Thanks
