i have a 327 sbc that i need head gaskets for . im just confused as to what ill need to buy because the engine has a .040 oversized bore , do i just buy stock gaskets with my desired thickness ?
The gasket bore diameter is published for every gasket. Most are around 4.09" to 4.1" that are made to work on a 4" nominal bore SBC. You want at least 0.030" between the fire ring and the bore. More room is not wanted if it can be avoided- it created a "dead area" that costs compression, causes more emissions and contributes nothing.soooo a stock 4 inch bore sbc gasket will work ?
