I have been busy with much of the same. Most of my work is with race cars and an occasional street driven hot rod. Here's an example of my involvement.xntrik said:
A good friend, Glenn was having problems with his super pro 66 Mustang. Some of you may recognize the car from Ford races in the Houston, New Orleans or Gulf Port areas. He runs a small flat tappet cam shaft in a high compression 351 Windsor. The car was running mid to low 10s but he was having problems with trace detonation at launch with a transbrake.
I cut grooves in his AFR heads and he opened the squish clearance. Normally I would expect the reduced squish to create detonation. The result was low RPM power that was too much for the car to handle. I was there for the first night out after the modification. The car ended up in the trailer because he couldn't control the wheel standing.
He has now softened the combination to allow launch with out excessive wheel standing. Needless to say he's convinced.
Here's some picture from his project and other recent activities.
