Use high quality silicone plug wires and keep them from direct contact with the headers. On small block Chevys I always had better luck running wires under the headers along the block then up to the distributor in the back.
The best thing is to buy high quality headers with 1/4 inch flanges and a ball and socket exhaust pipe connection.
Cheap headers will warp so the flanges aren't flat. Check them for flatness and clean both surfaces perfectly. I have had good luck with Permatex Orange high temp gasket sealer. I spread a 1/8" bead around each port and tighten. I warm the engine up then retighten. Then I check them once a month or so. I use loctite red. The exhaust pipe flange end can be tough if it is the flat, 3 bolt flange. I usually change to the ball and socket type connection which works fine. You can try the sealant on the 3 bolt flange. Sometimes it will work if the flange isn't warped too bad.
92 Silverado said:
Does anyone know of any type of gasket for headers that you dont have to replace every year. i have a 92 silverado with a 350 and i have shorty headers on it. not only do they leak at the heads but also real bad at the collectors. just wondering if anyone had an idea that has worked out good for them. i installed a set of header bolts that lock onto the header tubes so that they cant back out and that seems to work pretty good at the head but the collectors are starting to leak really bad. also does any one know of anything that can protect my spark plug boots from melting to the plugs due to the headers. Thanks
