Ive pumped the cylinder full of air before to lift a head. 175psi might help.
IF you can get the studs out, stick something in the intake port and pull.
If you wanting to save the studs, this won't work but you can thread on a nut and weld it on the stud. The heat and move down the stud and break the bond and the nut will give ou something to grab onto.
