I have a 59 Apache Suburban and I need to hook up the heater core. I understand the hose that sends water to the heater comes from the Water pump. But which side of the core is the inlet? They are the same hieght.
Your exactly right Doc, the cores that have the same size inlet and outlet do not have the valve.docvette said:Doc hereimp:
Try the top Hose to the water pump, If I remember that far back, I don't think it made any difference which way the flow went, (The Core Dosen't Care)
On the later Cores, The inlet had a Valve for water Flow shut off, where yours is old enough I think just mechanically Shuts a heater door on the Heater box. These usually are 5/8 and 3/4 hoses types , so you can't reverse them.
Hope it helps!
Docimp:
