hi, ive got a 70 skylark with a bad heater core. i think. i was just wondering how much of a hassle it would be to pull it out and inspect it. ive heard that i would have to pull off the entire right fender to get at it. Is this true?
Heatcore
I have heard it's a pain if I were you I would just replace it with a new one or block it off till you can replace it. See if you can just remove the inner fender cover so that you can get to it also you might check if the a/c heater blower fan is there I would replace it as well now that your there. Good luck!
WR: I had a leak in a Camaro and they said they would have to disassemble that car to even find it up under dash. I opened up incoming water line, put in Bars Stop Leak and problem went away for less than$10.00. Might be worth the try. . . DAVE
