I have a 355 SBC that I built about 7 years ago with close to 8,000 miles on it. Since day one it had sever blow by which I installed a PCV system to help with thinking the rings needed to seat. Well fast forward to now, this thing burns about 1qt per 250 miles give or take. I tore it apart 4yrs ago thinking it was my intake gaskets, no change. I then pulled it apart, ball honed it with new rings, no change. At this same time I also installed positive lock valve stem seals on the exhaust valves since I thought it was sucking oil past them. These heads were new when I built the engine. I also setup a homemade catch can for the PCV (running OEM valve cover with baffles) and it’s not collecting anything substantial.
While installing new headers last month I could see oil on all exhaust ports, heavy soot build up, and ash deposits on my plugs. Since the plugs were out I did a leak down test with a HF leak down tool. All cylinders were about 25-35% leakage straight past the rings. I am nearly 100% sure my machine shop did not use a torque plate. I don’t see any oil smoke when pulling away from stop lights, and very little at start up but there is the scent of burning oil most times. My right tailpipe is also oily, but the left isn’t. Both sides have significant leak down though so I just assume the right bank is “worse.” Before pulling this thing apart again to have it bored 0.040 over by a reputable shop, I want your opinions.
