1 - 8 of 8 Posts
So when i was dropping the v8 into my s10 i broke the rotor on the distributor (cap was removed) so my question is, do all HEI distributors use the same cap and rotors? Coil located in cap
life is a ride
more info please
GM hei dist. are generally the same physical size but there are levels of quality.
OEM, high performance coils and foreign made junk.
Why do you ask?
vicrod
Discussion Starter #3
I was just making sure i got the right rotor, the distributor is made by TSP, and i was just wondering if say an accel cap and rotor would be the same
life is a ride
not aftermarket
I assumed that you were referring to GM hei products or OEM replacements.
Can't tell you about aftermarket stuff.
vicrod
Just make sure you don't get the low grade cheap stuff, ask for brass pole cap and rotor. The cheap **** have aluminum poles, corrode quicker!
Banned
Accel makes a cap and rotor kit , it has brass terminals
as long as you get one for a chevy v8 engine and not any other
make (olds/catty/etc)
#8122 is tan # 8123 is black cap.
cap +rotor with brass kit
Old(s) Fart
Every GM factory style V8 HEI uses the same cap and rotor.
1 - 8 of 8 Posts
