1984 El Camino
350, 380hp. motor is pretty basic no emission or "junk" in there from the 80s, just basic setup.
Setting, This car was parked and gauge kept for 5 years, replaced battery no spark. I have around 10,000 miles on this motor and I put a brand new HEI GM distributor in, when we got the engine. Ran fine until I went to turn it over 10,000 miles and sitting inside for 5 years.
I’ve triple checked the power going to the Distributor while the key is both in “on” and “start” and have confirmed power is reaching the distributor cap. I even took it a step further and ran a wire straight for the battery as a test.
I have no tach, just a single wire to the "Bat" on the Distrubutor.
My first thought was the Coil, I took this with me to the store, could find none with a coil tester so I brought my meter with me and checked two coils and compared it to mine and readings were consistent. But I decided to buy the coil anyway since I figured under load perhaps it was a different story.
I’ve replaced the Cap, Rotor, Coil, and Ignition modal.
Tested jump plate with ohm meter on both wires. Both showed over 3Meg of resistance which is considered “Infinite?” so that checked out ok.
Confirmed the cap is turning with the engine.
Only thing left to check is the capacitor in there, which I could not find documentation for and it’s suggested since it wired in parallel it would not effect the operation.
After all the parts swap I still have no spark, even bought a spark tester today to confirm the results to be sure.
My father and I are stumped, something so simple but it just won’t give a spark. Any tests you could recommend?
