Carb Problem, HELP!!!!
Help!!!! I have a 1967 Chevelle with a 350 and the Holly 670 Avenger. Here is the problem that I am having.....When I press the gas peddle all the way to the floor the car seems to flood itself or gasp for air. I am really unsure which it is doing. I took the breather off to see if perhaps the carb was not opening up all of the way....in fact the front 2 flaps on the carb open up just fine but the rear 2 do not open at all. I am thinking that perhaps something is missing on the linkage to the rear 2 barrels. Do they or are they suppose to open up using some sort of vacuum? Should they only open up when I press the gas to the floor? Or should they ease open just a little while I cruise and then open up all of the way when I stomp on it? Any help would be greatly appreciated. If you need pictures let me know I will most certainly go and take some and send them.
